Hi Crossfire lovers i'm just starting a modification to my SLK R170 boot ( Trunk ) floor at present there is no provision to run a second exhaust to the right hand side due to the floor pan design and diagonal floor bracing bolted to it !!! ....... having studied crossfire pictures i can see Chrysler used a transverse floor brace to overcome the problem and allow your centre exit systems but this bracing only sees to be mounted on specific models........I'm hoping you guys can point me in the right direction as to which models had it fitted i'm assuming either the roadsters or srt6 to add strength ??? This would help me to locate a used one from a salvage yard and if anyone has a Crysler EPC the part numbers for the transverse and diagonal braces would really help as the SLK ones are unequal lengths !! ......Thanks in advance Simon
