Joef89
interesting, wonder if this is what's happening with my srt6. after about 45 min of driving the esp, has light comes on and the supercharger no longer engages. ( I assume its not engaging because of the eps light coming on) but have done all the normal stuff, pump, intake air temp, rcm, burped the fluid, looked for leaking intercooler.)
And if thats the case I'll strongly suggest swapping the ABS Module or at the very least get yourself a iCarsoft i980 and see what codes the ABS module is throwing. In the scanner it will show up as 2 different modules and neither one will say ABS, one will say ESP (which as abs and traction control) and the other will say BAS. If you need a copy of the shop manual I'll be more than happy to send it over.
What other symptoms are you having ? Does it also seem to fault when it's raining or on cold starts ?
