Joef89
I have an autel maxiDiag MD808, ill see if im getting any new codes as its been a while. but when it comes on if I cycle the key it stays off for a little while. Not as long as when you first start the car from a cold start. but right before the light comes on you will feel the car loose power then the bas esp light illuminates and that's it no more supercharger.
Sounds just like my situation, not sure if the autel lets you see the abs module or not but you'll need access to all 6 modules connected to the CAN C bus network, (1) Shift Lever (2) Transmission Module (3) SKREEM (4) Instrument CLuster (5) CAB/ABS module (6) ECU/PCM
