Old Apr 8, 2020 | 10:31 AM
dedwards0323
Default Re: Moisture Behind Driver's Seat
So you now say you have water in front, under and behind the driver seat?
I see all the HVAC unit being on the passenger side. The AC vent hose exits above the transmission on the passenger side. Everything is beside the centre radio console, so climbing the transmission hump would be hard.
I only found moisture behind the DS seat and under the seat as well.
A couple of weeks back, I found moisture in the DS footwell. I thought it might be related to the fact that I removed the OEM dead pedal and installed a M-B dead pedal using double-sided, industrial grade Velcro. But thought it strange as I've had the M-B dead pedal in the car for 2-3 years w/o any issue. Anyway, I soaked up the moisture, which was only at the bottom of the dead pedal, & re-installed the OEM version. No moisture since in the DS footwell. I even checked this morning again to see if the issue I'm having under & behind the seat is somehow related to the moisture I found at the base of the dead pedal. But the dead pedal area is dry.
