Old Apr 8, 2020 | 11:18 AM
onehundred80
Default Re: Moisture Behind Driver's Seat
I only found moisture behind the DS seat and under the seat as well.
A couple of weeks back, I found moisture in the DS footwell. I thought it might be related to the fact that I removed the OEM dead pedal and installed a M-B dead pedal using double-sided, industrial grade Velcro. But thought it strange as I've had the M-B dead pedal in the car for 2-3 years w/o any issue. Anyway, I soaked up the moisture, which was only at the bottom of the dead pedal, & re-installed the OEM version. No moisture since in the DS footwell. I even checked this morning again to see if the issue I'm having under & behind the seat is somehow related to the moisture I found at the base of the dead pedal. But the dead pedal area is dry.
Got any more info to share? Did you remove screws to get the old dead pedal off, water could possibly have come through the holes, but I am not familiar with the set up of the later dead pedals fitted.
