Old Sep 4, 2006 | 05:59 PM
andrew's Avatar
andrew
-C-I-C-C-I Associate Member
Default Re: Crud in the airbox
Originally Posted by richemj
Hey-
New to the site and new to Crossfires. A real rookie question here...I would like to change out my air filters to K&Ns, but can't figure out how to access the air boxes. I assume they are under the top engine cover, but can't see easily how to remove to access the filters without breaking a mounting point. I've learned not to muscle german parts for things break easily when pushed/pulled in areas where not designed.
Can anyone please send help... pictures...annotations!
Thanks much... look forward to good times on the site.
remove the 2 black air tubes at the front of the cover... they side back to remove. then pull up on the cover from the rear to release it. you may need to pull hard... rubber grommets hold it in place.
when reinstalling it... be sure to align the mass air flow sensor up first... at the back of the cover. this makes it easier to reattach it imo.
its easy to do... after you do once.
