Re: I hacked the Skreem, the Skreemulator
My post is not a commercial offer, I am currently using my solution in Europe to run these cars.
Because I found this thread on the forum, I understood that I should show the existing solution.
If any company wants to distribute this device in the US, please contact to PM.
Brief information on how to add My SKREEMULATOR (copyright for this pretty name - of course belongs to Viper-666) :
there are two ways:
One is to read the eeprom from the ECU (95P08) , from this data I will create content for the emulator.
Second way : the data needed to work the emulator can be read by communicating with the ECU via CANBUS , in this case it is not necessary to open the ECU, and as in the first case I create data content for the emulator from the information readed info content,
and as in the first case I create data content for the emulator from the information readed info content .
Using both methods, we do not change anything in the ECU files in and the data in eeprom remain original.
We can use the SKREEM immobilizer with the keys and the emulator- interchangeably an emulator and SKREEM, of course the emulator must be paired with other key numbers (the ECU has 8 keys stored) and cannot be connected simultaneously - we either use one or the other
