Old Apr 28, 2020 | 08:01 AM
  #6609 (permalink)
mastermikie's Avatar
mastermikie
@JoeO Actually they did total it. they gave me $5600 for the car and after buy back i had $4400. that was enough to get the control arm kit and front nose cone. just enough to make it drive able. i spent another $3500 out of pocket to have the lower control arm mount which was bent repaired, adjustable control arm bushings front and rear and get a set of matching rims back on it. but to make a long story short i couldn't find another vehicle for the money i spent that i wouldn't have to spend more on to bring to my level of expectation. i have kept this one serviced and know what i have for the money. not to mention the mojo this car has.
@dedwards0323 with the 25mm spacers there are 5 bolts that pass thru the spacer to the hub and 5 that hold the wheel to the spacer. think of it as a hub extension. that way your not riding on some really long bolts. btw those are eibach pro spacers. they come as a kit with the correct length bolts for the spacer to the hub. if they are too long they can dmg the brake components. so if you use spacers do the research. see pic.
@WD40 the rims are Touren tr70 silvers. they make a few different diameters and widths. however the ones i have on the rear are probably the last set anyone will find. it seems the 20x10 5x112 were out of stock everywhere. i was fortunate i contacted the distributor TWG and had them see if there were any available. they were able to find me 2 system wide and they were shipped from 2 different warehouses.
