Re: Illuminated Door Sills
Yeah, they take almost no time to install if you do it yourself. There's only 3 connections you have to make and they are all in the same wiring harness. However the instructions state that you need a torx 10 screw driver, however check the screws, they are much smaller than a T-10.
I was able to complete the install without the removing the screws shown in the instructions, however it would've saved maybe 10-15 minutes if I had.
Just make sure you do it when no one is around. I was out in the hot AZ sun for 3 hours answering questions from curious on-lookers, when the job would've taken a half hour otherwise.
