Old May 8, 2020 | 01:40 PM
GraphiteGhost
Default Re: Save on KYB Shocks & Struts at RockAuto
IF you buy a set of 4 OR rear shocks from RockAuto, make sure you install the rears first. RA site listed the set of 4 for my Ford Ranger Edge with 4.0L and torsion bar suspension/rear wheel drive was XX. The set of 4 with rebate (a couple years ago, am remembering they were KYB), the rear mounting point on the axle was not the right size to accept the bolt (smaller bushing). I had to send all 4 back because I needed 4 PLUS the rebate was invalid if all 4 were not used (two front with returned 2 rear, equaled NO REBATE). Had to buy a different set of 4 with a higher price. Am glad I tried the rear replacements first, just the one attempted replace was a lot better than having to install fronts then finding out the rears would not work. IF you buy from RA, make SURE you install/use BEFORE the 30 day return they specify on the site. Buyer beware!
