Has anyone used some of the newer sensors on the market and the one I am referring to is this that is on RockAuto by Denso # 5502505:
OE Manufactured When a TPMS Sensor fails, you'll want to replace it easily with a DENSO First Time FitŪ TPMS sensor. Unlike one-size-fits-all sensors, DENSO has developed sensors that never need to be programmed or cloned before installation – they're built to the specified vehicle right out of the box {note: new ID numbers will need to be registered through the OBD II port}. With DENSO, installation is a snap — their TPMS Sensors relearn just like an OE part, restoring the vehicle to its original condition.Service sensors with DENSO's First Time Fit TPMS components every time the tire is removed to ensure safe operation.
Features
- Immediate coverage for applications which cannot be programmed
- Tested to OE specifications
- 10 year battery
- OE technology preserves diagnostic trouble codes
- Quick, direct-fit installation (no cloning or programming)
Denso First Time Fit Sensor
TPMS Guide
TPMS Sensors typically need to be replaced for one of the following three reasons:
- Battery Life – Estimated life of 5 to 10 years or 100k miles
- Damage – Caused by accidents, pot holes, etc
- Corrosion – Typically from road salt (cold weather climates) or galvanic corrosion
Note: It typically makes sense to replace all sensors at once since batteries have similar life spans
Should I replace my TPMS sensor when replacing my tire?
- If the new set of tires is expected to cross over the TPMS battery threshold consider replacing the TPMS Sensors now to avoid tire mounting fees
- Otherwise TPMS manufacturers recommend using a service kit to replace TPMS components to prolong life
Installation Instructions
Power Source Electric Monitor Type Direct Real Time Pressure Signal Transmission Yes Mounting Method Clamp In Mounting Hardware Included Yes Universal Or Specific Fit Specific Gasket or Seal Included Yes Alternate/OEM Part Number(s): 5096808AA, 5127335AD, 52088990AC, 52088990AD, 52088990AE, 8973271890
Warranty Information:
12 Months
