Re: Just got my new Fuel Filter
According to the service manual (excerpt below) outlining the pressure relief procedure, you MAY receive a code:
1. Remove the fuel filler cap from the fuel filler neck.
2. Remove the fuel pump fuse from the relay control module (3) located next to the PCM.
3. Start and run engine until it stalls.
4. Attempt restarting engine until it will no longer run.
5. Turn ignition key to OFF position.
6. Return the fuel pump fuse to the relay control module.
7. One or more Diagnostic Trouble Codes may have been stored in PCM memory due to fuel pump fuse removal.
The DRB IIIT scan tool must be used to erase any DTCs.
