Old May 17, 2020 | 09:42 AM
Fla_Xfire_SRT's Avatar
Fla_Xfire_SRT
Default Re: Auto-Stuck in Park
Originally Posted by amx1397
as for the tcm,,, you said you had other crossfires swap the tcu/tcm to check it ,,,limited to limited and srt to srt they do not interchange so if this is a limited you can put in a tcu from a limited / and save your 3400. if you need a tcu i can get one for you for around 500 programed to your car's rear end.
Thanks for the reply, I am going to wait on swapping out those TCU units, thanks for the tip on how to swap them out....until after the fluid change and conductor plate and connector have been replaced if that doesn't fix the problem. ....new front grill on the way...woohoo.
