Old May 19, 2020 | 02:38 AM
  #341 (permalink)
jamesmcaleer's Avatar
jamesmcaleer
Default Re: p0410 secondary air injection system malfunction solution?
Originally Posted by BobG
Is there any reason to not just temporarily pull the 40A fuse controlling the secondary air injection pump?
My plan is to replace the relay, but meanwhile I am tired of hearing the pump cycling on and off. Pulling the fuse would stop such cycling and possibly prolong the life of this poorly engineered pump and subsystem.
Hi there, you can do that or you could disconnect the wiring plug by just pulling the supply off where it goes in the pump
Either will be fine
