Too many cars
"…...Also, the BAS/ESP light illuminates frequently. It will stay off for some time after doing the steering wheel turn to rese..... ….with the steering situation. Any advice would be appreciated."
You have done this car EXTREMELY well! About the ride and the BAS/ESP? Have you inspected the connections to the wheel sensors (for the light) including those wear sensors, CLOSELY? I am guessing you checked all the suspension bushings/connection points for damage or loose? Finally, have you gone (when all has been checked/repaired) and done a complete 4 wheel alignment? The 4 wheel is a lot more complicated than the 2 wheel with rears 'kinda' checked. I say this because some shops will say a 4 wheel but they do not have the right equipment for a MB suspension to do a correct 4 wheel (defrauding you). You MIGHT want to get the rear camber/other suspension parts so they can be set up 100%, as the rears are factory non-adjustable (from most of what I read),
BEFORE YOU GET THAT ALIGNMENT! I foresee many more miles on this car due to your careful thoughtful restoration! Good luck (I have a feeling you will not need luck though!)…
