Old May 23, 2020 | 07:21 AM
dedwards0323
Default Re: TPMS Mysteriously Working Again - After 3 Years!
You may be on to something with the grounding issue. Interesting that you've noticed another issue solved on the MB shift **** when you installed the new ground cable. Like I said previously, have the Tire Shop scan your wheel sensors prior to performing any work to see if all the wheel sensors are functioning properly. More then likely they are since the TPMS warning light is no longer lit.
