oldmercman
2004 coupe, 30k miles ...runs perfect.......drove 50 miles to friend.....no issues whatsoever......On my way back home , the esp/bas light came on. ....after a few miles, I pulled over and did the steering lock to lock drill,
Shut it off, restarted and headed out again......with in 1/ 2 mile, light came back on again. When I got back home , I did the steering deal again.....light went out....pulled into the garage and let it idle.....within a minute , light came back on. Shut in down and plugged in my NEXPEAK NX501 reader.....no active or stored codes........The brake light switch and the "yaw" sensor have been mentioned a possible causes.
Where do you start ? what has been the most common culprit ? p/n's..? source ? When I bought the car from original owner at 24k miles, I did a complete brake upgrade with new cross drilled /slotted rotors, pads, and wear sensors. All new Continental Extreme tires. Car is perfect, garaged all winter . It's a great car.......very uncommon in my area. I don't mind replacing parts if needed......but not on a trial and error process. Any help appreciated.
The most common culprit is the brake light switch and it's best to get a genuine Mercedes (0015456409 for the automatic transmission). You might want to try another code reader to see what the exact code stored is. My MB II code reader couldn't read the BAS/ESP modules when there was a code but zero problem with no codes stored. The Autel MD802 was able to read the code as a Mercedes SLK320. The brake light switch code can be stored in the BAS/ESP modules and one time it was stored in the transmission module.
When the light is on, if your brake lights do not light up when depressing the brake pedal or the cruise control does not work then for sure it is the brake light switch. Otherwise it is best to see what the code is first.
