Old May 25, 2020 | 04:31 AM
zip439's Avatar
zip439
Default Re: Suspension: Checking rubber bushings and ball joints
Astrofriend, are you aware of the adjustable bolt kits for the front lower control arm bushings? read this pdf : eccentric bolts
If the front lower control arm bushings go bad. It is often easier to buy a new control arm because it comes with the bushings installed. It is a difficult job to replace those front bushings, but it can be done and the eccentric bolts give you camber adjustment so long as the car is not lowered. If the car is lowered then it is best to use the K-mac bushings for additional required adjustment. The rear lower control arm original bushings are very soft. If you replace them you may want to consider making them adjustable for camber. Check out this website: K-mac
