Mr. Max
Thank you, Zip. I checked #9 and the socket. I'll check the central pump locking system.
Max, you misunderstood what I was trying to say. Remove fuse 9. It will disable the theft/siren system. The Fob will no longer open and close the doors. I would then disconnect the cars battery for about one minute which will reset some of the electronics. Then try starting the car without fuse 9 in place. If your lucky it will start, if it does the two attempts then nothing. Your right back at the SKREEM problem.
