Old Sep 5, 2006 | 11:08 PM
stryfox's Avatar
stryfox
Default Re: Illuminated Door Sills
Originally Posted by jpristel
Yeah, they take almost no time to install if you do it yourself. There's only 3 connections you have to make and they are all in the same wiring harness. However the instructions state that you need a torx 10 screw driver, however check the screws, they are much smaller than a T-10.
I was able to complete the install without the removing the screws shown in the instructions, however it would've saved maybe 10-15 minutes if I had.
Just make sure you do it when no one is around. I was out in the hot AZ sun for 3 hours answering questions from curious on-lookers, when the job would've taken a half hour otherwise.
Weird, mine was only 2 wires at the harness by the passenger side (left) a pillar, plug the connectors into the sills and that was about it.
I needed no torx driver just a 10mm socked to loosen the center console to sneak the driver side (right) wire behind it.
