racingagent
I tried yesterday to remove the cowl, but I was afraid to apply too much pressure to get the wipers off. How hard are they to remove, and is there a special tool needed to perform the task?
ZERACER
Yes, a small gear type puller.
ala_xfire
OR, I have always had luck just raising the wiper arm with the nut off, then gently rocking the portion on the shaft.
If you raise the wiper arm so that the pressure against the windshield is eliminated, you can get a small terminal puller to pop the wiper arm off. A search for
battery terminal puller on Amazon, eBay, etc. will give many purchase options. Or you can pick one up at a nearby discount parts store; also a nearby Harbor Freight.. It will probably be a little scary the first few times you do this. Wiper arm is secured to the shaft using a tapered, spline fitment and the final torque really locks it down.
Norton Search
Likewise when you re-install the wiper arms, get them positioned where you want. Then while applying a small amount of pressure to secure it to the shaft, raise the wiper arm to finish tightening. Again, try to keep the pressure caused by resting against the windshield from applying a bending-moment at the shaft. I've had to repeat the removal & install a couple of times before I got the wiper arm where I needed it to be located. You can mark the end of the shaft with black scripto & put a small mark with a white scripto on the wiper arm (at the edge of the mounting flange rim; won't be seen when you install the nut cover).
Later,
