dedwards0323
Likewise when you re-install the wiper arms, get them positioned where you want. Then while applying a small amount of pressure to secure it to the shaft, raise the wiper arm to finish tightening. Again, try to keep the pressure caused by resting against the windshield from applying a bending-moment at the shaft. I've had to repeat the removal & install a couple of times before I got the wiper arm where I needed it to be located. You can mark the end of the shaft with black scripto & put a small mark with a white scripto on the wiper arm (at the edge of the mounting flange rim; won't be seen when you install the nut cover). Later,
A SMALL dab of lithium grease wiped on the spline will forever allow EASY removal, onward!
