Old Jun 4, 2020 | 12:16 PM
GraphiteGhost
Default Re: Erratic / Intermittent HVAC Blower / Fan Fix
Originally Posted by THETESTER
I respectfully disagree, the voltage should only change when the dial setting is adjusted, ie from a setting of say 2 slow speed, up to a setting of say 5 full speed. Random changes in voltage to the PWM (resistor/regulator) via the pink wire would cause the blower motor to run erratically, just as we are all seeing.
The voltage should be constant for each dial setting. I however confirm that I did not make it clear that my comment (item 4) was to state that the voltage was fluctuating without any change to the blower speed dial setting.
Kind regards
Mark
Errrrr, trust me when I say you cannot respectfully disagree if you didn't make it clear you didn't turn the ****. Good luck with your fix.
