Re: Numerous problems after 65mm and tune
Ok so at a glance the pump seems to be fine, haven’t thoroughly tested it yet. But we did a current test on the throttle body and throttle position sensor to make sure that those were working. While the sensor (thankfully) was fine, the throttle body failed to give any resistance back as per the specs provided in the instructions. So replacing that and see if that fixes everything.
