mkemike1
Took my 2005 coupe out of storage and drove it home. All good. Ran perfectly. Pulled into my garage and parked it. 30 minutes later, its started making a loud beeping noise every 30 seconds. Started it,, drove it,, no noise. Parked it and the noise started again. The battery is good. I disconnected the battery and the beeping continued. Has anyone experienced this? WTH??? Thanks for your help. Mike
Sounds like the siren has triggered. Have you LOCATED where the beeping is coming from (AFTER you removed the NEG battery cable)? Check the lower hatch cavity for water. If none, pull the wire for the siren under the cowl. You might have a leaked siren battery and it is activating. Come back when you locate the beeping, we can go from there.
