Re: Still won't staft9
~ Wing up usually means bad battery....bad battery usually means faulty charging system.
~ Inspect the Transmission harness connector for "O"-ring leakage.....If found..
~ Lift the carpet in the passenger footwell and unbolt the cover that houses the TCU and inspect for signs of fluid wicking....Replace the transmission harness connector adaptor...($12.00 or so)..
~ Stuck in park may be a result of a spill into the shift selector module...
~ If you decide to replace the shift selector module, study the video on "ash tray fix" to learn how to disassemble the center console....expect 15 yr old brittle plastic clips to break.
