Old Jun 16, 2020 | 04:27 PM
onehundred80
Default Re: emptying oil-how you do it?
Originally Posted by zip439
The only way to remove oil from the differential is with a suction. It won't gravity flow out unless you lift the car with a crane hanging it from one end.
Another post says to warm up the oil with a drive and then carefully loosen the fill plug to make sure it will come out. Then carefully remove the drain plug.
