Old Jun 17, 2020 | 10:46 AM
  #324 (permalink)
onehundred80
Default Re: Valve cover leak...
Originally Posted by phil alvirez
when following dedwards advice using plated steel bolts for the breather covers we can increase torque to twice compared to aluminum bolts, hence reducing the possibility of leaks.
see chart: https://www.holo-krome.com/uploads/7...edatachart.pdf
here shows that torque for N5 is 12Nm (about 10 ft-lb) , double the figure advised for aluminum bolts (6Nm)
and no more breaking bolts again.
right. the torque is for the bolt, not for the aluminum. back to 5-6 Nm.
now, how those low figures can be measured? which torque wrenches are within these ranges?
the most common start at 10 ft-lb
My 1/4” square drive torque wrench starts at 20 in/lb (1 2/3 ft/lb)
