Old Jun 18, 2020 | 07:37 AM
  #332 (permalink)
phil alvirez's Avatar
phil alvirez
Default Re: Valve cover leak...
and from post 62, and the comment from 180:
Quote:
Originally Posted by MikeR
use some blue loctite on the bolts when you torque them down.... that should keep them in place...
and then 180:
Applying Loctite may not be a good idea, this would probably act as a lubricant and using a torque wrench would allow the screw to be turned more than the specification value which is for a metal to metal contact. When cured the release torque required may leed to the head snapping off.
I realize that some people use steel or stainless steel screws but the OEM's are some aluminum alloy and that is what my comments refer
so seems that somebody has considered using loctite blue...
but havent seen any really using it-or similar-neither results...
