Old Jun 18, 2020 | 11:45 AM
Ronman's Avatar
Ronman
Default Re: tire light on dashboard
Yeah - It is a "bummer" in that the TPMS on the Crossfire only tells you there is an issue. We don't know whether it is a defective wheel sensor or which one. Could even be a defective TPMS Module. If it is just low tire pressure, we don't know which tire. With some of the newer systems, the warning light will ""blink" if it is a system defect. I might have that backwards on whether the blinking warning light is for a system defect or low tire pressure. For the model years back then, probably a fairly good system.
If you get the DRB 3 emulator it reads the TPMS module and will tell you which tire is low, defective sensor etc. Yes not being able to see it on the dashboard isn't ideal but this is from around 2003.
