Re: Need NEW NOS/OEM Driver's Side Door Ledge/sill Window Seal Strip!
Sussudio
I’ve found a place in Germany that has more than 10 of them, but they won’t send it here due to Covid. No problem though. I’ve got a couple of ideas I’m going to try on it as it’s not super bad. I think I need to adjust the window a bit as I’m getting a little hissing in the front upper corner and that seal at the top is in almost new condition. I just really wanted to avoid taking the panel off but that seems what is going to have to happen. This might help with both problems.
I adjusted my window and the tilt adjustments are made through two holes in the bottom of the door. The door panel does have to come off. It's explained in the Service Manual.
Here is a photo showing the adjustment points.
Reason: Inner door panel has to come off. Tilt word added.
