Re: A/C Pre(?) season system inspection/check?
The positive (red ) one and BE CAREFULL !!!
It's best to connect the wire to the clutch connector, NOT THE GROUND SIDE then touch the other end to the positive terminal.
The other way, you are carrying a HOT wire around many ground sources. Burns or fire can result !!!!
