Old Jun 30, 2020 | 10:07 AM
  #54 (permalink)
onehundred80
Default Re: Chrysler Crossfire Double Din Kit Ready For Production
Originally Posted by aliozgur
Hi everyone I just saw the posts over here, when I posted the pictures I thought no one had interest in the project and haven't checked the forum after a while thankfully Sussudio informed me with the post. And he gave the updates. And pschlan thanks for your objective reviews and pictures this means a lot!
Having 2 trims that one has airbag light and one doesn't will increase the costs in R&D and molding for us which will actually make the sale prices higher which I think it will not be tolerable considering our group buy price is already $300. There are nothing much to differentiate on low quantity manufacturing since the costs are increasing rapidly. Whereas I would recommend punching a hole on the transmission trim so it can fit. Otherwise the costs will not be acceptable compared the prices we have provided for group buy.
No our kit is plug and play. However you may need to cut the bottom portion of the plastic housing that is made to hold single din HU in order to convert it to Double Din. If you can cut it percisely with dremmel you will be able to stick it back with using epoxy glue or super glue.
I will be checking the forum more frequently to answer all the questions and reviews!
Stay safe everyone!
The bottom shelf is best cut with a hacksaw blade in one of those that clamp on the end, the blade is flexible and cuts neat and flush with the side wall. You will not want to put it back anyway but you would need to fill the gaps at the edges if you did as the gaps would be too large.
