Re: 2006 Hard Start Issue
FloridaCrossfire2006; What you are describing when the starter engages and continues to turn the car over when you release the key from the "start" position is a normal Mercedes feature which is incorporated into the Crossfire. There is nothing wrong with that starting sequence. A good scan tool designed to get into the Mercedes diagnostic codes should help you find the fuel related issue. Most generic OBD scanners can not help you with that.
