Old Jul 1, 2020 | 03:56 PM
KJN's Avatar
KJN
Default Re: Need NEW NOS/OEM Driver's Side Door Ledge/sill Window Seal Strip!
Originally Posted by JSK
I stand corrected!
Well I was parked next to an older SLK recently and decided the belt moulding on it looked like the belt moulding on my Crossfire. Then I saw a thread where someone had installed door cards on a Crossfire from an SLK and the fit was perfect so I ordered a belt moulding for an 03 SLK 320 from a MB parts supplier on line. It was about a hundred bucks and fit perfectly
Jeff
I have an 99 00 01 02 03 04 MERCEDES SLK Door-Window Sweep Belt Molding Weatherstrip Right side. I was going to replace the one on my 06 Roadster.
Is this the same SLK part you had that firt the crossfire?
I also wanted to know if you had to take the inside panel and window off to replace the window seal?
Thanks in advance for your reply.
Kevin
