tadmaz
With the fuel level sending unit out, will it be obvious if the tank is collapsed? I can swap tanks if need be just might be a few weeks to get the time. When I was pumping gas, I forced it to overflow, kept pumping and shutting off, and pumping. First time filling the car, how was I to know there was a problem...
I am not saying the tank has collapsed, it happened only once or twice here.
The service manual will tell you how to check the readings on the in tank sensor on a multimeter.
Quit the guesswork and check the basics.
The tank is sealed and not repairable except for the sensor.
Good luck.
