Some update. Straightened the base part a little and connected the diffuser to an aluminum flat bar. Screws will be cut.
There is a gap between the diffuser and the aluminum flat bar so the diffuser will be filled with construction foam to avoid water and dirt
The diffusers will be connected with 3M double side adhesive and adhesive promoter at any place I want. The rear bumper won't be drilled into.
