Old Jul 14, 2020 | 12:03 AM
  #364 (permalink)
tighed1's Avatar
tighed1
Default Re: p0410 secondary air injection system malfunction solution?
Originally Posted by RedInterior
Chased P0410 leisurely the last few years. Changed the little valve A 002 140 84 60, but the code kept returning. Did the full troubleshooting by the manual and this forum, found nothing wrong. I concluded the most likely part to cause the issue is the relay. Bought the M-B A 170 545 03 05 relay module and put it in last summer. No more P0410 faults. Some here say they have found the faults within these modules. I cannot find any bad solder or cracked foils in the one I removed. But I can say with confidence the replacement relay module fixed it.
Take the spring off of the air pump relay (relay on edge of the board).
Flip the braided wire over the top of the relay and pull the armature out.
Bet the relay contacts are burnt up. That's where the PO410 comes from 99% of the time.
Relay can be replaced for way less then buying a new unit.
