I bought two Picker PC 822-1A-12-A-X relays and this relay’s pin layout does not match the holes on the PC board!
Specifically, the two pins on the front of the relay are 8 mm apart and the board holes are 10 mm apart! See photo.
Since I bought two relays I tried bending the pin on one of them. Not surprisingly, it’s not working out.
Have others encountered this problem? If so, how did you solve it?
OR can someone please id the manufacturer and part number of a relay whose pin layout matches the board?
Thank you!
