Old Jul 15, 2020 | 01:51 AM
Crystal's Avatar
Crystal
Default Re: Oil Level Sensor
Yes, I actually knew mine was leaking before I removed the oil pan. I was under there because of the trans leak and I was just looking everything over. I saw a ton of oil in that area and I posted about it. I posted pictures too. Bob McCubbin told me my oil level sensor o-ring was leaking. It was obvious when I removed it.
Originally Posted by 208james@gmail.com
Thanks. Is it possible to see if the oil sensor is leaking without taking off the pan inorder to know if I need to order one before starting. I am assuming I can see it if I remove the plastic rock shield under the car. I did look at the transmission sensor and it may have a small leak but didn't get to removing the rock shield to look for the engine oil sensor. Thanks
