Old Jul 19, 2020 | 02:13 PM
  #373 (permalink)
onehundred80
Default Re: Valve cover leak...
Here are the instructions for the Permatex Ultra Black, it says to apply and assemble at once.
DIRECTIONS:
  1. For best results, clean and dry all surfaces with a residue-free solvent, such as Permatex® Brake & Parts Cleaner.
  2. Cut nozzle to desired bead size – gaskets are best formed using a 1/16″ to 1/4″ bead.
  3. Apply a continuous and even bead of silicone to one surface, surrounding all bolt holes. Remove excess with knife at once. Assemble parts immediately. Do not squeeze out silicone by over tightening bolts. Re-torque will not be necessary.
  4. Silicone dries in 1 hour, and fully cures in 24 hours, at 70˚F – 50% relative humidity. Allow more time in cold weather.
  5. Replace cap after use. Clean hands with dry cloth or Permatex® Fast Orange® Hand Cleaner. Clean tools with non-flammable cleaning fluid.
NOTE: Not recommended for use on head gaskets or parts in contact with gasoline.
Here is a video on how not to apply the sealant, but he sure is confident.
https://www.google.com/url?sa=t&rct=...T2c5pBhTrjnq9u
