Old Jul 20, 2020 | 11:40 AM
phil alvirez's Avatar
phil alvirez
Default Re: replacing Driveshaft Support and Bearing
so far, i have got some great advice from amx1397 about critical details that if you dont know, may get you into trouble.
1- if your bearing is good then just slip the support over your bearing.
2- look at how it looks before u take it apart.
3-you do not have to remove the entire shaft; just the rear 1/2.
4- just get the arrows correct when replacing.
5-to get the drive shaft out, remove all the bolts at the rear end.
6-drop the support bearing. u need that removed from the car to have flex to drop the driveshaft from the rear end.
( U DO NOT NEED TO REMOVE THE COMPLETE DRIVE SHAFT.)
