Ceramic pads had no difference in my brake pedal issue. Changing the old used OEM DOT-4 fluid did. I think there are many different reasons for a deep pedal feel. My issue was solved with a DOT-4 fluid change using a brake vacuum bleed kit, using the recommended wheel bleed procedure in the service manual.
