Old Jul 24, 2020 | 02:06 PM
onehundred80
Default Re: Too Much Brake Pedal Travel?
Originally Posted by Pop Tro
You guys could confuse a genius.The pushrod I'm talking is the one entering the mc.Natually it cant push the internals but should just touch.If the internals back off to the retainer clip that hold them in then expansion doesn't even come into play.I don't care if the mc is merc somebody makes the parts and that could be a hair different.Did the mc get bench blead before install?Has the fluid been pushed backwards a lot while changing pads,thats a no-no.Everything is designed buy smart people,second guessing will drive us nuts,in my case its a short drive.Pops
In the post where I mention expansion, I use the words "is or was". In the post #14 I mention the fact that I should have measured the gap but failed to do so. Some systems have an adjustment to set the gap, our cars do not have it. Your comments on various lengths are understood but having no adjustment in the system would call for tighter tolerances on the parts used.
The brake pedal was noticed to have a large throw before I changed the MC, the new MC was bled using dummy tubing as normally practised, no difference in the throw was found when it was all put together and bled. The pedal is not spongy but solid and the car brakes well, it is the pedal throw that is too much.
