Old Jul 25, 2020 | 08:17 AM
onehundred80
Default Re: Tips or info on brake pad changes or brake fluid change?
Originally Posted by JSK
I had the same issue three or four years ago, it’s evap system and secondary air system that won’t clear. There are no codes or pending codes, I can be tested with one test incomplete but not two. I have found multiple sets of drive cycle instructions, it’s hard to do ten minutes of 43 mph here, it’s either city driving or freeway, and ambient temps have been quite high lately. I’ll just keep driving, it’s got to get there sooner or later. It’s not all that bad, I could be driving a POS car. Oh, I caused this, I replaced the battery a couple weeks before I took it for emissions and never drove it after the battery swap.
Those are exactly the same two codes that I had trouble getting rid of some years back. I am going to check what codes I have now as the battery was disconnected during the winter and I have driven the car for less than 70 miles since.
Here is a PDF of today's reading of the smog check by my BlueDriver, after less than 70 miles there is only one fault and that is the Evaporative System. See the PDF below.
Here is the Drive Cycle that I used to get rid of the two codes the other year. See the PDF below.
File Type: pdf
