Old Jul 25, 2020 | 08:37 AM
onehundred80
Default Re: Too Much Brake Pedal Travel?
Originally Posted by chriscat32
I swapped out my brakes on my limited coupe to SRT brakes. I did calipers, rotors, pads and SS lines. In my opinion I had less brake peddle travel and quicker brake action with the limited setup.I ran two quarts of fluid through the system to make sure there was no air in the lines. Just my two cents.
I have often wondered if air had got into the ABS module on my car but the ABS works fine when tested on wet roads.
Your experience makes me doubt that assumption, bluecoupe reckons my pedal throw is greater than on his SRT.
It makes me believe that my pedal throw is greater than most SRTs.
