Old Jul 25, 2020 | 12:08 PM
ZERACER
Default Re: New guy, 2004 Crossfire
Welcome. what exactly does won't start mean? When you turn the key does the engine turn over? If it doesn't turn over does the fan run? If you disconnect the neg. cable for a bit and then reconnect it does it then try to start? I believe it can be fixed, we just need more to go on. The most likely causes are the RCM, screem or connections.
