Old Jul 30, 2020 | 03:27 PM
  #377 (permalink)
dikzak's Avatar
dikzak
Default Re: Valve cover leak...
Originally Posted by twanger
If the bolts you have removed look good after cleaning I see no reason not to reuse them as long as you're very careful w/ proper torque & tighten them gradually in an apposing pattern .
Do NOT over do the sealant application ! Although not normally my process , some folks just LIGHTLY & evenly snug the bolts & then tighten to torque after letting the sealant dry overnight
This does make sense allowing some more compressive sealing of the mating parts .
If you are at all unsure of aluminum bolt torque specs , look it up online .
Well the thing with aluminum is that it suffers from metal fatigue really quickly, that's why I'm so hesitant to reuse them. I've seen the 'first finger tighten, then torque down' approach mentioned in this thread before, it seems like a good idea.
I sadly couldn't really find any info online about these bolts other than that the allen bolts are M5*18 and made of aluminum; noone really mentions the E10 bolts.
Originally Posted by THETESTER
Hi dikzak
I have just completed the breather leak, just waiting to crank the engine and do a run to see if I have been successful.
The short bolts M5-0.8 x 16mm are made from aluminium and are freely available in the UK in a handy pack of 5.
Part number - AL-CAP-M5-16-5PK
GWR fasteners Ltd, Unit 6-7 Artillery Business Park, Shropshire. SY11 4AD
These should not be re-used. (all I could find for the torque was 1ft/lb. That to me is finger tight).
The longer bolts holding the small breathers to the rocker cover and head can be used again, just clean them up prior to re-use. (Torque 9.5N/M)
Thanks for the reply! Is 16mm long enough though? As far as I'm aware the originals are 18mm long.
So the E10 bolts are not made of aluminum, or at least are strong enough to be reused? ( I'm a metal fabricator, and aluminum is a PITA to work with. I really don't wanna strip the threads or break the head off.)
Funnily enough, the service manual really doesn't even mention these little m5 bolts. It pretty much ignores the existence of the breather covers completely other than passively mentioning that they are for crankcase ventilation.
So just for clarity's sake:
-the allen head bolts are M5*18 with a 0.8mm thread pitch, but M5*16 will also work?
-Torque on the allen head bolts is basically fingertight?
-The E10 bolts can be reused with a torque of 9,5NM? ( My service manual says 10NM, but that's within margin of error)
( Also, excuse me for using this username: I really only made an account so I could download attachments. Didn't figure that I would actually post something, so I just chose some random name. 'Dikzak' means fatass. )
