Old Aug 1, 2020 | 09:55 AM
onehundred80
Default Re: turning sharp there is a crack-crack noise
Originally Posted by phil alvirez
eventually i removed the stabilizer rod that is mounted across and the noise is gone-and steering improved.
I would not advise the permanent removal of the stabiliser cylinder at all. It buffers road forces reaching the steering wheel and helps eliminate tram lining for one.
Your very first tip other than one direct from the internet or a known tip on the forum is a bad one, try again.
