Old Aug 2, 2020 | 05:28 PM
Ronman's Avatar
Ronman
Default Re: Skreem and key now available in Canada
Originally Posted by flaco1801
Hi 180..The spare Skreem is a used one programmed to your Vin?..The Skreems that Needswings supplies are from salvaged vehicles and reprogrammed to our Vin so our keys still work...There are so many posts but i havent found anything definitive to explain the system completely...Fob with the chip, the ring around the ignition,the actual key cylinder and the skreem working in tandem with each other...It's all very confusing to a new owner...thanks, jeff
Yes the skreem has to be programmed to the specific car by VIN. Where did you get your info that Needswings uses skreems from salvaged vehicles?
